how to model this in using sheetmetal
You can draw it flat then insert a bend. Help can explain inserting a bend more.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP0.1 / PDMWorks 05
Firstly I hope this isn't what it looks like:
1) Enter the Sheet Metal mode.
1) Select the Base Flange/Tab icon & create the vertical flat section as your Base-flange1.
2) Select the Edge Flange icon, select bottom edge of Base Flange.
3) Select Material inside (first) icon under Flange position
4) Select Edit Flange Profile then grab an end point of the line which is on the bottom edge of the Base Flange & move it toward the centre of the edge. Do the same for the other end point then click in graphics area to select direction of bend.
5) Dimension to suit then click Finish
There are other methods, but I find this to be the simplest.
[cheers] & all the best.
LOL, it's definately not a hoax. Yahoo assigned that name to it. Thanks for the tip. I did not know you can do that.
I can open it. Copy it into another browser window.
Chris
I get:
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Please try the following:
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
See if your Internet connection settings are being detected. You can set Microsoft Windows to examine your network and automatically discover network connection settings (if your network administrator has enabled this setting).
Click the Tools menu, and then click Internet Options.
On the Connections tab, click LAN Settings.
Select Automatically detect settings, and then click OK.
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Cannot find server or DNS Error
Internet Explorer
Scott Baugh, CSWP [pc2]
3DVision Technologies
faq731-376
faq559-716 - SW Fora Users
I copied & pasted the first URL & also used ctophers link without problem using Firefox.
Could not get access using IE.
Must be a browser setting.
I don't know of any other way of uploading my stuff to. does any know of a free ftp/picture host website?
Here is a link for a free picture host website.
It is :
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
here's the pic at a different host
sheetmetal9ax.jpg]
Scott,
For some reason I can not email you from your web site. The email address link on your cover won't go thru.
m1mason's link works.
Chris
ctopher's home site
