How to Model - Fitting to Fitting
  • Thread starter Thread starter GBBHSI
  • Start date Start date
G
GBBHSI
Guest
I am would like to know if there is an easy way or what is the best way
to model flexible tubing that would connect one fitting to another (we do
not have piping). See attached jpg for what I am trying to do.
Thanks in advance.
GBBHSI,
Easiest way to do this (without Pro/Pipe) would be to create a sketched datum curve between the two fittings and then to produce a swwept thin protrusion based on that trajectory
Kev
Try...
Insert > Advanced>pipe... There is an option to select whether the pipe should be straight or splined....
I just tried that and can see the spline, but how about the pipe definition? I put in the pipe diameter in the options but all i get is a line representing the spline that I created.
J
Create the pipe as a PART in Assembly mode and not as a FEATURE.
Thanks for the information. I am going to give both options a try.....
some people in the military sector (I have heard and see with me own eyes) have used ISDX for routing thru an assembly thru top down design. Then you sweep the solid circle up the isdx curve. Updates wonderfully. I understand ISDX will work in assembly mode with WF4.0
