I was wondering if any one has some sheet metal design experience regarding api 12f storage tank tops.Attached is a flat layout that we cut our tops from. when you cut these tops and lay them out on the table with a 1/12 slop they work perfect. i i can not get my solid works model to match. when i layout my working solid works model in the flat it could out to big them they go to weld the to half's together.
has any one else had this problem?
