Hello!
Assembled components/ interlocking components (interlocking bars, coupling etc) are always regarded as one component in fea or at least the elements of different components in an assembly are sharing the common nodes where they meet. However, in real life, when the assembled components are subjected to rotations or motion, the coefficient of friction between the components changes and the assembled components might slip against each other. I can’t model contact element, because assembled components usually have very small tolerances for tight-fit purposes. How should I model?
Regards, mel
Regards, mel
