How to measure the PUMP Power Consumption instantly?(3 phase 220 V) 2
morris more
TW
How to know the Power Consumption of the pump instantly ?
How to measure it ?
The electricity source is 3 phase and voltage is 220 V.
I want to build the relation graph between the flow rate and Power Consumption of the pump.
A pair of current transformer, a current transducer, and a voltage transducer will provide the information to determine motor power consumption.
Measuring the input at the motor terminals will give you the overall power consumption that includes the pump and motor inefficiencies, is this what you are looking for?
This information is readily found on the pump curve.
Most vendors will provide one if you've lost it.
What make and model of pump?
What's written on the pump itself?
Using a Clamp Meter ??
If there are three hot wires connect to the motor , I can clamp one of them and read the current and voltage by the multimeter.
Then how to figure out the power?
Or I need to buy the AC CLAMP POWER METER?
3 phase power can be a bit odd, but there are many online calculators.
what sort of pump is this?
Why can't you use the pump data sheet / pump curve?
You can use a clamp on ammeter and assume the other phases are carrying equal current. Measuring the current on two legs simultaneously will give a more accurate result.
Guess you can use what ever you like if your happy with it, and as you don't seem to take notice of member comments by a simple response to their input, why should we be concerned.
