I have a microprocessor and a surface profile call out pointing to the bottom surface of one of the pins. There are 48 total pins.
I understand the theory of what surface profile is (somewhat), but I'm unsure on how to measure it.
We do have a microscope scanner that can produce 3d height map renderings of the leads.
The way I see it, it can be one of two things.
I can create a plane on each individual pin, and then create one much larger plane out of all those planes. Then, I can measure the z difference between the large plane and each individual small plane.
Or, I can measure the surface roughness (min and max height) of each individual pin bottom.
