Chandan321
- Apr 24, 2008
- 32
I am designing a steel staircase tower 4m x 6m in plan area and 63m in height, divided into 2.4m high flights. The following are the details of the structure
---- At each landing level, there are 4 steel beams all around.
---- The steel staircase tower is supported on 4 pedestals.
---- I have used k brace at all elevations in both directions.
---- Basic wind speed is 50m/s.
---- I have applied wind load as per standard Indian codes.
---- I have divided the height of the structure into 4 groups as per wind pressure zones.
---- I have applied wind load on all beams, columns and bracings in each direction separately
---- I have used a shielding factor for farther frames
---- Dead load = 1.2KN/m2, Live load = 3 KN/m2
I am getting too much tension in the anchor bolts at the top of the pedestals. I know from previous project information that 8 bolts of 1.5 inches would be sufficient. But, my tension is way too much high.
Guys, I want your suggestions on how to reduce the wind load on the structure so that I can reduce the tension in the anchor bolts.
