I want my part measurements to be associative - that is, when I rotate/translate a part, I want the measurment to tell me if I've made the right move.
Additionally, I also want to highlight elements when I select them. By default, the element edges highlight. I want the whole element. (for tasks such as split and intersect - much better display method, especially when zooming in close)
I can't seem to be able to find this in the options. As it is, I've worked in the past on someone else-s pre-set config, and never had to ask the question.
Thank you.
Check out CATBlog!
Thank you.
Check out CATBlog!
