How to make extrusion wich will start as circle and end as square
bruyoni
YU
Basically what I’m trying to do is to make pipeline reduction that will start as round pipe and and as square which is 30x40 cm. what I wanted to do is to make solid that has the same shape as inner volume of reduction and then to make shell.
And problem is how to make such solid.
Do you have any tips and tricks for me?
Thank you
Miran
I don't believe there is a way to do this in AutoCAD and have it be a solid. If you have a friend with solidworks or Inventor he could export it for you and you could put it in to your file.
If it just for visual purposes you can you faces. Unfortunately the command has left my memory and I can't think of it right now.
I presumed it coudn't be done i AutoCad. And how to do it in solidworks, i know i'm boring but i am novice in solidworks. I done basics and am lerning more and more day by day.
Thank You anyway
Much easier to do in SolidWorks. Start a thread in the "SolidWorks 3D CAD Products" forum here.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
There is a possible way in ACAD but it will require four separate commands, the last of which will be repeated four times.
Draw a circle and extrude it; draw a square, circumscribing the circle, and extrude it in the opposite direction with a taper so that it flares out; union both; at the junction of circle and square there are four separate faces, each to be extruded in the direction of the cylinder with a taper identical to the one used above that made the prismatic shape. you will need to calculate to probably four decimal places the depth of extrusion for the four faces so that they terminate into points tangent to the cylindrical surface.
In Turbocad, I use a "LOFT" command between 2 2D entities. A Square and a Circle. I then make a scaled down copy and then subtract one from the other.
Here is a pic
The .igs file is at
Cad is not my specialty so I may have misunderstood what you needed.
Gerald Austin
Iuka, Mississippi
In AutoCAD 2007 it is possible using the loft command. Also doing a helix.
