How to make Catia active during running a macro
Macro2015
Automotive
Jan 19, 2015
10
I can not figure it out how to make Catia active during macro is running.
I mean when I run a macro and everything is done and Msgbox is displayed, I would like to scroll the expand tree or zoom in/zoom out/rotate the model.
I just want to be Part design active during macro is running. How to do that?
Thank you in advance for any suggestions,
I appreciate if you could help me with this, when msgbox appears i would like to be able to click on tree and rotate the model..please see below
thanks in advance
Sub CATMain()
Dim partdocument1
Set partdocument1 = CATIA.ActiveDocument
Set part1 = partdocument1.Part
Set selection1 = partdocument1.Selection
'selection1.Search "CATPrtSearch.PartDesign Feature.Activity=FALSE"
selection1.Search "((((((CATStFreeStyleSearch.Point + CAT2DLSearch.2DPoint) + CATSketchSearch.2DPoint) + CATDrwSearch.2DPoint) + CATPrtSearch.Point) + CATGmoSearch.Point) + CATSpdSearch.Point),all"
'************************ here I want to be a Part design active! I want to roate the model, clicking on tree...
MsgBox("The number of points is: " & selection1.Count )
End Sub
U want to make a macro who will count points in part or? And if u want to make a selecetion u must do it like this
Dim InputObject(0)
Dim oStatus
oStatus = oSel.SelectElement2(InputObject, "Select the Sketch, points etc", True)
with this u can select one element, if u want more u must use multiselection
