How to loop through already opened .CATDrawing files in catia v5 using vba
Sidtha
Aerospace
IN
Is there any possiblity to loop through already opened .CATDrawing files in catia v5 using vba.
If yes please help me with code
I found below code but its counting sheets inside the same CATDrawing file.
Dim drawingDocument1 As Document
Set drawingDocument1 = CATIA.ActiveDocument
Set oDrwView = drawingDocument1.Sheets.ActiveSheet.Views
Debug.Print drawingDocument1.Sheets.Count
For i = 1 To drawingDocument1.Sheets.Count
Set oSheet = drawingDocument1.Sheets.Item(i)
oSheet.Activate
Debug.Print oSheet.Name
Next
BR Siddu
Code:
Sub CATMain()
Dim V As Integer
Dim StrWindows As String
Dim DrawingExists As Boolean
DrawingExists = False
Set windows2 = CATIA.Windows
For V = 1 To windows2.Count
    StrWindows = windows2.item(V).name
    MsgBox windows2.item(V).Parent.name
    If InStr(StrWindows, "Drawing") Then
        DrawingExists = True
        MsgBox StrWindows
    End If
Next
End Sub
You can loop through CATIA.Documents, check whether the type of a Document is DrawingDocument.
Code:
Sub Main()
    Dim n As Long, i As Long
    n = CATIA.Documents.Count
    Dim doc As Document
    For i = 1 To n
        Set doc = CATIA.Documents.Item(i)
        If TypeOf doc Is DrawingDocument Then
            Debug.Print doc.Name
        End If
    Next i
End Sub
Use LWolf's solution as it enumerates "opened" documents meaning the ones that have their own window.
Although I'd adjusted "if" condition, because right now it matches ANY documents that have word "Drawing" in them (i.e. "AssemblyForDrawing.CATProduct")
Code:
Sub CATMain()
  Dim win, doc, drawingExists
  drawingExists = False
  For Each win in CATIA.Windows
    Set doc = win.Parent
    If TypeName(doc) = "DrawingDocument" Then
      drawingExists = True
      MsgBox doc.Name
    End If
  Next
End Sub
