stuckagain
Hello all! I am trying to design some parts with CAD and am 3D printing them to test in advance of production with metal materials. I have vertical rod that will oscillate and am affixing a platform that will hold certain masses. The masses will oscillate with the rod and needs to be level. The levelling may shift over time or by location of the machine, so would like it to be relatively easily adjustable. Here is what I have so far:
The top "arrow" platform is separate from the coupling on the bottom. The coupling will fasten to the rod through the 2 holes on the side using nut and bolts. The rod will extend to the top of the platform such that it is not higher than the platform. The rod is threaded. I imagine the coupler will have 2 holes on the top of each side that can extend through the top platform (but should again not extend past the top of the platform). Those holes can also be threaded if needed.
I feel like there should be some type of screw that can be used / designed that can both fasten the coupler to the arrow platform and also adjust its level - but need some help on how to achieve. Any ideas?
Thanks!!
Thanks!!
