how to import node coordinate tables in femap 1
hanspeter
DE
Hello folks,
just have a question:
I have a table of node coordinates as an txt and also as Excel File (from Mathematica) and I would like to import this table into femap and create the same nodes on the same position as in Mathematica. How can i do that?
Thanks a lot!!!!
best regards
Hans Peter
1) try "import model", see what happens, what format it's expecting.
or 2) create a dummy model (say 1 element, 4 grids), export an analysis model (ie get a .bdf file), insert your points, copying the formating from the existing GRID cards, and import this.
or 3) wait for Blase to answer !
Quando Omni Flunkus Moritati
That's fairly easy to do with a FEMAP API program. I have one already that reads 4 coordinate points per line and creates a surface from them. The file would just be a CSV file exported from Excel or similar program. It would be easy to change it to just create a node. Let me know if you want me to post a sample.
Chris Teague | Sr. Applications Engineer |
Saratech, Inc. | 26054 Acero, Suite 200 | Mission Viejo, CA 92691-2768 | USA |
@ cpt09135 that would be nice if you could post it.
my solution was to export a femap neutral and to edit it as a text file. So i could write a node list, safe the document and read it in again.
for example, FEMAP Neutral entry: 2 Nodes with xyz 0 and x=88 yz 0:
927
-1
-1
403
1,0,0,1,46,0,0,0,0,0,0,0.,0.,0.,0,0,
2,0,0,1,46,0,0,0,0,0,0,88.,0.,0.,0,0,
-1
-1
404
-1
Best greetings
HP
Dear hanspeter,
Please find attached your gift. I create it especially for you ...
You can create the number of nodes you want with the appropriate defCsys and OutpuCsys...
Enjoy :)
rb1957 4/ or waiting for me to drop a gift :)
 http://files.engineering.com/getfile.aspx?folder=916e5d25-eb09-44a1-898f-9d784f96c72f&file=Create_Nodes__Send_Data_to_Femap.xlsm
Hi compositecurves!
thank you very much for the gift! Its a pitty, but it is not working.
It seems that the code is not compatible with my FEMAP 10.3.0 64bit Version. :-(
The VBA code is PW protected so I can not update this information. (also to see the code would be interesting for me)
Can you provide the PW and a tipp (maybe I am wrong with my incompatible suggestion)?
Thank you very much for your effort!!!
Best greetings!
HP
Hi hanspeter,
i attached the file without PW. Sorry but i protect automatically my API program :)
and in VBA go to tools/references/and upload the "femap.tlb" in the Femap directory then press ok
Try and keep me in touch
Best regards
Hi composite curves!,
thank you very much! It works fine!!!
Now I can start my excursion to FEMAP API :-)
Thank you!!!!
You welcome!!
If you need more help or if you have some questions contact me.
Best regards.
