jochav5280
Hello All,
Does anyone have experience with applying a Modal Response Spectrum Analysis combined with AISC's Direct Analysis Method (DAM)?
Per Chapter 12 of ASCE 7-10, certain horizontal and vertical structural irregularities disqualify the use of the Equivalent Lateral Force Method (ELFM) for generating seismic loads. In my experience, most of my colleagues don't check the irregularities and used the ELFM on everything they design. I find this is largely due to ignorance of the code requirements as well as due to the simplicity of the ELFM.
We use STAAD for analysis/design, and I've found that while it will perform a Modal Response Spectrum Analysis (MRSA), you can't directly combine the results with an iterative analysis such as P-Delta or the DAM. STAAD's technical help has indicated that the only way to combine the MRSA results directly with DAM is to combine them via superposition, which ignores the P-Delta effects associated with the DAM.
STAAD's technical support has tried to help me come up with a method in which I manually create a static load case that represents the results of the MRSA, but I'm finding that this will be very labor intensive. I'm responsible for explaining how to implement the MRSA with the DAM to my colleagues, and am afraid that this manual creation process will be criticized for it's difficulty and labor intensity.
That said, could someone help me understand how the MRSA results should be combined with DAM? I don't believe we can ignore the P-Delta effects, especially since my seismic loads are the controlling lateral loads, which would lead to the greatest P-Delta effects.
I'd appreciate any insight you could give me. Among the (20) engineers I work with, nobody knows what to do here.
Thank you very much in advance,
jochav5280
jochav5280
