How to hide unwanted parts in structure manager for NX assembly
ashivu123
Aerospace
Oct 24, 2013
153
I want hide some components in structure manager, even suppressed components also showing up in the structure manager. I don't want to delete the component is NX
If you want it to be removed from structure manager, but still in NX assembly then set the component (In NX, rightclick on component - select properties) to reference only. Then save assembly.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
Sorry, if I understand good, you do not want to see part in graphic window and you do not want to see it in assembly manager, but you do not want to delete it from assembly because maybe you would use it latter... so how do you think to access it and make it active if you do not see it anywhere in assembly?
Check whether Attributes IGNORE_MEMBER or REFRENCE_COMPONET will work.You can find them in File - properties [Individual parts]. Not sure whether you have to add this attributes manually.
"Component is reference-only" is working now. Thanks all
