How to hide coordinate table in move component tool 1
JPH_
Automotive
FI
Hello fellows!
Can i hide coordinate table when i am using "move component"- tool. The reason why i want to hide that table is because it's ALWAYS on the coordinate axes and makes it difficult to move the component (see picture). When i change the angle of view even a bit, coordinate table moves on the axes and i have to move it first. That's is really frustrating.. [thumbsdown]
There is no permanent solution for this (unfortunately), but you can use the F3 button to hide it (it will come back the next time you use it)
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
yes it is an annoyance! this was supposed to be fixed back in NX9. the only thing that i do is drag it out of the way, another mouse click!
Scott Copeland
Thanks for the answers guys! That F3 command works perfectly for me [smile]
@scope63
"this was supposed to be fixed back in NX9."
- Did you report this as an IR to Siemens GTAC and You got that response ?
Tomas
i believe it was questioned when 8.5 was around,there was something written way back then about this as well.
Scott Copeland
