I have a connecting rod designed with a plain spherical roller bearing with both sides sealed with a shaft seal. In the con rod I have a grease fitting for applying grease once the con rod is installed on to the crankshaft. normal amount is around 20 manual pumps.
My concern is that during greasing, the air trapped inside the conrod housing creates excess pressure and pushes the seal out of the housing.
Is there a way to remove the air pockets while the bearing is being greased? Also is there a grease fitting available that will prevent excessive greasing?
