how to get the ultimate load for concrete beam in ansys?
RJcivileng
TR
hi,
I made a model for concrete beam , and apply the load as load steps, and then I made static non-linear analysis , but.....how con i define the critical or the ultimate load that the concrete beam can stand before collapse and how can I now the results for each load step? how can I draw the (load - deflection)curve for the beam???
thanks.
to draw, use 'chart and table' :
'Selecting the Chart and Table icon button allows you to create charts of loads and/or results against time. In addition you can also chart result quantities against a load or another results quantity.'
from ansys help @ :
// Mechanical Application User's Guide // Features // Results in the Mechanical Application // Results Related Topics // Result Outputs // Chart and Table
