How to get points from exiting curve in NX
Ponnaiyan
Aerospace
DE
I have model with some curvature, I want to get points in x,y and want to export the same to Excel
well, hm,..
how many points do you want ? 17 or 23 million points ?
how should these points be spread over the model ?
What is the purpose of sending points to excel ?
Tomas
Thank you for your response.
I want points in the interval of 0.01 mm so count based of overall length,
my curve is 2D of bell shape.
i want to spread in excel or some table , for some other analysis(study) purpose.
AR Ponnaiyan
I would use NXOpen for this - it has functions for querying curve / spline objects at parameter locations.
If you are stumped by this response give me a shout and I will throw something together for you.
the out of the box reporting does not have , to my knowledge, a feature to only report the coordinates for multiple points in one go.
Ie, you can select multiple points and then go Information - Object and see the coordinates, but you will also get other data reported such as type of object , layer, color, name etc.
Or, you can go Information - Point and get the report you ask for , but you cannot select more than one point at a time...
I think you would need a custom journal to create this report.
Creating the points :
Menu - Insert Datum / point - Point set... Curve Points , Curve points by = Incremental arc length, select the curve, enter the distance. OK.
Tomas
Thank you so much. I think I have to create custom journal to get the report for multiple point on the curve
Thank you for your response,
I am using NX12
AR Ponnaiyan
Find attached a part with my solution, It's full parametric but time consuming to create all the points
Didier Psaltopoulos
Thank you so much, But How to export to Excel
