How to get Coordinates of a point in a drawing View. 1
sriram99
Aerospace
Dec 10, 2012
35
Hi Everyone,
I have a number of point in a view for which in need get (x,y,z) coordinates and the add a text with leader need to add the coordinates and some text.
I'm trying automate it. I could able to select the required points but not able to get the coordinates.
Help is much appreciated.
Sub CATMain()
Dim i As Integer
Dim coord(2)
Dim dwgDoc As DrawingDocument
Set dwgDoc = CATIA.ActiveDocument
Dim dwgViews As DrawingViews
Set dwgViews = CATIA.ActiveDocument.Sheets.ActiveSheet.Views
Dim dwgView As DrawingView
Set dwgView = dwgViews.ActiveView
Dim Point1 As Point2D
Dim pointSel As Selection
Set pointSel = dwgDoc.Selection
pointSel.Search "Name='GeneratedPoint Point',sel"
MsgBox pointSel.Count
For i = 1 To pointSel.Count
Set Point1 = pointSel.Item(i)
Point1.GetCoordinates (coord)
MsgBox "(" & coord(0) & ", " & coord(1) & " ," & coord(2) & ")"
Next
pointSel.Clear
End Sub
Thnaks,
Sriram
I think a problem is in a line:
Code:
which should be changed to:
Code:
Set Point1 = pointSel.Item(i).Value
If you are iterating over a selection, you are dealing with SelectedElement object. To get a "real" selected object from SelectedElement, you have to use its Value property.
Tesak
- Play Tetris in CATIA V5 drawing
why not use the Coordinate Dimension Table that's already in CATIA?
Hi Jackk,
I don't want to list out all the coordinated in a table rather my requirement is to show the coordinates at that specific point.
After getting the coordinates of each point,for each coordinate value I need to concatenate some text.
So I can't use Coordinate Dimension.
Thnaks,
Sriram
Hi Tesak,
Thank you for your Suggestion.
I tried it but it is not working.
Thnaks,
Sriram
Hi Tesak,
error is attached.
Thnaks,
Sriram
It seems that variable Point1 is not a Point object. In order to find what object is behind Point1 variable please add this line into your code:
Code:
MsgBox TypeName(Point1)
and insert it behind the line:
Code:
Let me know what do you see in the message box.
Tesak
Hi Tesak,
This is message.
Thnaks,
Sriram
Hi Tesak,
Sub CATMain()
Dim i As Integer
Dim coord(2)
pointSel.Search "Name='GeneratedPoint',sel"
Next
pointSel.Clear
End Sub
Thnaks,
Sriram
I think it is a kind of bug in CATIA and it seems that you can not handle generated items of the view like lines, curves, points properly by VBA. If you try to approach them from inside VBA, you get a DrawingView object.
However, if you isolate the view & change your search query to look for points (not GeneratedPoint), your script should start to work properly.
Tesak
Hi Tesak,
May be it is not possible using VBA but if I use CATIA.StartCommand ("Coordinate Dimension") after the search function it is generating (x,y,z) coordinate.
So, may be it can be possible with different programing language.
Thanks you very much for the support.
Thnaks,
Sriram
use the function to get the table, read the values from the table, make what you need, remove the table.
Eric N.
reading info on isolated 2d point might not bring XYZ coord.
Eric N.
