KLineDesign
Bioengineer
- Aug 9, 2007
- 135
Hello, we allow use of in-context modeling for test fixtures and other non-production items here at work. This works great on a lot of the typical situations, but there is one where this doesn't work, and that is in-context components. We were doing tubes in-context (they are defined by a 3D sketch that varies) to connect several components, but these tubes only will show the current configuration in the drawing. Please help if you have suggestions for fixing this, the goal is to not have multiple tubes that are essentially duplicates. I have the proper named configurations selected, and I have allow multiple contexts for parts turned on, but we can't get this to work correctly. What am I missing?
To ask or describe this another way: We have two views next to one another of an in-context component that changes shape across two different configurations, but only the current configuration in the assembly will display in each view rather than the individual configurations. What gives?
Thanks for your help,
KLine
KLine
