How to get a linear motor to act tangentially to a cylinder
amrbekhit
30
Hello all,
I am trying to apply a linear motor to the highlighted part in the image below:
As you can see, selecting the outside surface of the cylinder creates a linear motor which acts along the cylinder's axis. However, I need the motor to act in such a way that the cylinder is pushed along the slot shown in the model. The only other parts of the cylinder that I can select are the two faces at the ends and their corresponding edges. How can I go about doing this?
--Amr
Make a dummy part that is mated and oriented the way you need, then apply the motor to that.
You can also try to add a sketch in the slot and mate your pin axis to that.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of these Forums?
Thanks for both your posts - it's all working now.
--Amr
