I'm a novice user to UGS much less solidmodeling, but fortunately have some machine shop experience so the paradigm shift from traditional CAD is hard but not impossible. OK in the attached file I have to close a duct, you can see a wireframe outline of the duct where the curvature is compound, the crossection gets deeper as the duct bends around. Any ideas on how to do this?
1) I thought to try to use sweep to sweep through the crosssections, but am getting bogged down in the details.
2) Thinking to use a Boolen compbination of solids in interesection to fill the region in and then try to copy a second scale it to some large fraction to hollow it out.
The file is attached. Any suggestions for a novice and which way to go (or a third way...) is appreciate.
Oliver
Oliver
