how to fix errors?
pagheca
31
While changing one dimension of a part I got into an error.
The problem is that apparently there is no way to go back: if I right click to delete/edit the component, or any other component I can't get anything. Apparently the only way to proceed is to start from scratch, creating cascades of errors in all the related assemblies.
What to do?
thanks in advance.
If you change a Parts dimension then you need to check the part. Try opening the part see if there is an error in the part. If so then fix it. If not then you will have to track it down in the assembly. Maybe the part was in-contexted and making the change caused another part to fail. It's your respondiblity to track down the problem. SW cannot do that for you.
Scott Baugh, CSWP [pc2]
faq731-376
