Unless this is some kind of odd shaped column or you are running into the plastic region of the stress/strain curve a hand calculation should be all that is needed. FEA would be driving tacks with a sledge hammer.
Thank you desrtfox , I have sensors attached to the internal side and I could calculate their response and it corresponds almost to the experimental results.
