Hello all! Greetings from the structural engineer's forum. As a structural guy I always get a little nervous around problems with objects not in "equilibrium"
I have a simple counter weight / motor problem. I've done some home work (old posts, my old dynamics book, etc...) and I've come up with a solution but since I've never really solved a problem like this I would love some feedback.
The problem:
I've attached a sketch with the problem and my solution.
Basically there is a object attached to a cable that is pullied over to a counter weight object of roughly equivalent weight. There is a drive cable from the counter weight to a winch. The simple question is what is the power required of the winch to move the counter weight and original object?
My solution:
I drew a free body of the counter weight and determined the tension in the drive line using ΣFy = m * a
Then I used P = T * v to solve for the power required to draw the cable at the given speed.
I came up with P = (CounterWeight / g * a)* v (see my sketch)
Additional questions:
How do the blocks effect the solution? with a given diameter I assume you can add some factor in the lines for inefficiencies.
How does the cable (weight and elasticity) effect the solution?
Does the drum diameter gear ratio etc. effect the power required? It seems to me they only effect the speed and torque.
How do differences in weight between the object and the counter weight effect the system?
I'm looking for max power required, so I assumed this is at max acceleration. How doe the power requirement change after acceleration finishes and it is running at the given speed?
anything else I am overlooking?
Like I said I am a little new to these types of problems but I am very much interested in learning. Any comments or suggestions would be greatly appreciated.
Thanks!
The problem:
My solution:
Thanks!
