Would the following iterative calculation provide a reasonable estimate of pump rundown time?
The hydraulic system P vs Q relationship is:
PT = PS/QS^2 * QT^2
PS = operating pressure at start of rundown
QS = operating flow at start of rundown
QT = flow at time T
PT = pressure at time T
Flow Energy is expressed:
FE = PT * QT * T
substitute into FE = PS / QS^2 * QT^3 * T
The pump Rotational Energy is:
RE = .5 * I * WT^2
I = moment of inertia
WT = rotational speed at time T
WS = rotational speed at start of rundown
assume WT = WS / QS * QT
substitute into RE = .5 * I * (WS / QS * QT)^2
For a small time interval (T), solve for the loss of Flow Energy (FE), subtract it from Rotational Energy (RE), then solve (RE) for the new (QT), substitute and solve for (FE), then repeat until flows and pressures reach minimum acceptable values and the sum of time increments is rundown time.
PT = PS/QS^2 * QT^2
QT = flow at time T
FE = PT * QT * T
RE = .5 * I * WT^2
