How to edit surface
asong
28
Can 3D surfaces be edited like solid? subtract or union, or trim.
Unfortunately, no. That would be too easy.
All editing of surfaces must be done using the sundry options available under the "Terrain" pulldown menu, or through the Terrain Model Explorer.
What/how do you need to edit the surface? I may be able to help point you to the correct tools.
Oops - sorry. I failed to notice that you are a Mechanical engineer, and gave instructions for the Land Desktop software that Civ-E's use. I probably can't help much.
Open the dwg file with Rhinoceros, hack away at it, and save it as a dwg file. Rhino can do all that you would logically expect AutoCAD to do with surfaces, and more.
Better, open a _copy_ of just the parts you want to change, and edit that. Rhino may not preserve some AutoCAD entities.
It may be necessary to add one linear dimesion in Rhino to avoid a scaling error.
Mike Halloran
Pembroke Pines, FL, USA
I am working on a surface which a 3D curve revolves along another straight line, and I want cut this surface with a plane to see the intersection.
But solid can not do the job.
You can convert many meshes to a solid using "m2s.lsp". Once you have a solid, you can get an outline of a slicing plane using the "section" command.
You can get "m2s.lsp" from
Author has an update to work with 2007, if you need that you can email him (address included in the lisp file).
If the curve is planar, you can add radials to the axis at its ends, turn it into a closed polyline, and revolve it to produce a solid of revolution, which you can slice at will.
Before you start, set the variable DELOBJ to 0 to retain primitives along the way.
Mike Halloran
Can you create that 3D surface with solid commands then use shell command to create that same 3D surface with a thin wall; then you probably can slice it with a plane.
Thanks for all your comments. I will try.
Thank you CarlB, M2s works.
