How to draw a line between these two planes?
  • Thread starter Thread starter kingston123
  • Start date Start date
K
kingston123
Guest
This is the diagram I drew: View attachment 2091
I successfully created offset to a plane but failed to draw a line.
There are many methods to draw a line. And there are many positions to place the line.
To draw a line (like the red line above) centered on the circle and perpendicular to the plane of the circle:
(you don't need a sketch for this - you can draw directly in space)
1. use the Point command and draw a point in the center of the circle
2. use the Line command and draw a line
- line type: PointDirection
- point: center point of circle
- direction: plane of the circle
- up-to-1: front face of the block
There are many methods to draw a line. .......... the block
I can't understand literature. Can you show me by gif format?
