How to do this with sheetmetal feature 1
fsh27
Industrial
ES
Hi all,
I would like to know if there is anyway of doing this with a sheetmetal feature.
Thanks!
Airin
NX Designer
Draw a centerline across, then use the bead feature. Lanced ends.
Tomas
Thank you Toost!
It works :)
Airin
NX Designer
Why you do not do it with sheet metal contour ?
I have to say I´m a novice at sheetmetal.
My first attempt was Contour flange but an error message was displayed:
Now that you´ve said this I´ve tried again:
1Step:
2step:
3step:
4step: (make a contour flange without the last curve and then make a normal flange)
But I can´t set inside material!
workaround: (make fillets in the sketch)
Airin
NX Designer
Yes you right
it seems like a buggy
I tried it and it allow me to finishe half
of the profile only.
That's a pretty ridiculous bug!
( I tried it in NX8.5 and, yes, it's a bug.)
Will you report it to GTAC ?
Tomas
Yes, I´m doing right now.[thumbsup2]
Airin
NX Designer
