how to do multi section surface/solid without curing the edges
NIMANIMAX72
SG
hi
i want to do a multi section between two section(a circle and rectangle) with two guides(a line at top and a curve in bottom) after doing this edges on the right and leftbecame curved instead of going straight.(without guides it is fine and straight)
how can i solve this problem?
If it's fine and straight without the guides, then don't use the guides.
Or, use straight lines for the guides.
NO
I need it to be curved at top angled at bottom and straight at sides
why don't you bring picture in your post the right way?
Eric N.
why don't you force the curve edges to go straight by declaring guide curves?
Eric N.
