I don't think that you mean that the elevation values are in the properties dialogue box. The elevation values should be in their own layer. With that said, then when you open the properties dialogue box on anyone of the elevation values you will note a specific format and related information geared for that particular elevation value.
If you used the text command to type out the elevation values, the properties dialogue box will a somewhat different format and obviously related information for that text. Normally, you would use a text command and not an attributed block to type the elevation values but it could be done without difficulty.
Properties dialogue box will not have quiet the same format for drawn objects, attributed blocks, texts, X-xrefs and groups.
