HarshParekh
Automotive
Fluid flow pressure from the right side. The cylindrical valve attached to spring is supposed to open at a given pressure.
In the picture attached what diameter to select to calculate the area to determine valve cracking pressure? 16mm or 19.8mm diameter? Theoretical there are 2 cracking pressure? Sorry if the answer is obvious
I ask because test results shows something strange.
