I’m trying to minimise the thickness of a rotating disk and I want to know what limitations there are. First it has to be a uniform thickness disk, the rotational speed, the material used and the basic geometry of the disk are known (apart from thickness). Are there any direct relationships between thickness and rotational speed/ stress? After going through nearly all research, I only found equations about the deformation, tangential and radial stress. No information on how to determine minimum thickness of a disk.
