Hello Community,
i need help in defining the connection between x3 and x1 (kinematic constraints). My Professor can´t explain it well, im confused. Is there a scheme on how to determine the kinematic constrains?
Task:
A homogeneous cylindrical pulley (mass m1, radius r1) has a rope S1, which is connected to the surrounding area via a spring (stiffness c)
The disk rolls on the horizontal
plane. The center point of the cylinder is connected to block 3 (mass m3)via a second, rigid rope S2
The rope S2 is guided via a massless deflection pulley 2
(radius r2), on whose bearing the constant frictional torque
MR acts on the bearing
In the sketch, the spring is relaxed and the
system is released from rest
Determine the speed v3 of the block 3 as a function of its deflection x3 from its rest position.
Given: m1, m3, g, r1, r2, c, MR.
Task:
