How to delete a partitioned section? 1
Bruno V
12
After having partitioned my instance under Assembly, I try to delete one the two created partitions. Can this be done?
When I click on Feature/delete, it will only let me delete the entire instance. It is not possible to select only one partition.
I tried to follow the same procedure in Parts, but I face the same probleme there.
Does anyone know how to solve this?
Thank you in advance.
Best regards,
Tools —> Geometry Edit —> Face —> Remove should help with that.
Thank you so much! It works :)
Really appreciate it!
