How to define displacements in element coordinate system
Alexfalkon
Computer
ES
Hello everybody,
I'm would appreciate if someone knows how to define displacements on nodes according to element coordinate systems.
I'm working with a shell-281 model and I have to put a symmetry to a curved line that is only defined with nodes. This is because I have updated the geometry of a previous small model and then I have reflected it so many times to do another analysis. So I have the finite element model (with nodes and elements) but without any line or area.
So the question is how to define displacements and rotations on nodes of a curved line according to the element coordinate system. I would have to put one displacement and two rotations to zero (this are the symmetry conditions as everybody knows).
I would be grateful if anybody knows how to do that (or know that it's impossible to do) because after reading the ANSYS 12.1 manual several times I haven't found how to do that.
I'm using ANSYS 12.1.
Thanks a lot in advance,
Àlex
why not answering this post? Any idea please?? anybody?¿
Alex,
I may be wrong, but I don't think ANSYS will offer displacements in the element coordinate system. Seeing as you're dealing with isoparametric elements, I'm not sure how you would use it any way. As I recall, the element coordinate system isn't to the same scale as the global coordinate system. In local coordinates, an element would span from -1 to 1, but (for example) it could span from .125 to .438 or from -38 to 5 in the global coordinate system.
Thanks!
But... how could I define a symmetry boundary condition on a curved line? A line defined only with nodes (and elements also).
Help please.
