How to define a setting in .dpv file NX 7.5
vimaldevk
Automotive
DE
How to define a new setting in site.dpv file
for example i want define Model Tolerance (Distance) to 0.01 mm and Model Tolerance (Angle) to 0.1 deg ?
Please help.
Thanks,
vimal
Hi Vimal,
I am not sure but can you try opening it in a text editor format (notepad/wordpad) and then try doing the changes in the default settings.
Best Regards
Kapil Sharma
In NX, open the customer defaults (File -> Utilities -> Customer Defaults), change the defaults level to site. Note: if the site level says (Read Only), you will have to change permissions on the files/folders you want to write to. Once you have the proper permissions set, make your changes (be sure to have the proper units selected, you can have different settings for metric/english files) and OK the dialogs to save your new settings.
www.nxjournaling.com
Keep in mind that the specific default for modeling tolerance is a "Part" setting and that even if the default is changed if the template parts for "File-> New" are not also changed the effect of the changed customer default will be obscured by the template part settings.
HTH, Joe
Hi All,
Thanks for your suggestions, i am able to open the user.dpv which i received from one customer. But i am not sure how to define this new settings in it.
Is there any standard procedure for this.
Vimal
It's not really advised that you edit .dpv files. Rather, you make your changes using...
File -> Customer Defaults
...and these changes are written to the .dpv file automatically.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
