How to create Radial Section Cut on NX Drawing 1
Jashe
Automotive
Jun 19, 2013
209
I need to know how to create radial section cut on NX 1919 Drawing. I've attached a picture of what it looks like. I've tried playing with the Section Line tool but it just seems to only work with straight lines. Can anybody help?
Ok Thanks, You could look for a command called "legacy Section" and try to create this view in a model view. But, I do not think this will work without having the PMI License, but you could try.
If this works, you could create this "curve section" and then process this view down into your 2D drawing VIA using the model views.
I hope this helps a bit.
Thanks.
Thanks.
Thank you for the response. If I had PMI, can you give me a quick synopsis of to go about doing that?
Here is a very basic video. When you right click on your toolbar go to customization. Search for Section. Section View (Legacy) should show up.
  • 2025-06-09 08-35-29.mp4
    24.7 MB
