fighterpilot said:
Ok, let me get this straight. Option 1 model defines one bend and option 2 model defines another configuration. If a feature, such as a hole, is common to both and I modify the hole, will the modifcation show up in all models?
Or, if I have an assembly, can I assemble in all the various option models?
First off - if you have an "option" defined in a design table, you will basically have a row of data, corresponding to your parameter heading.
That is to say, if the diameter of your hole is defined, and in Row 1, is assigned a value of 2mm, and you wanted a new "configuration" with only a change in this diameter, you would start Row 2 by copying all of the existing parameter, and change the value of ONLY what you wanted changed. (in this case, change the 2mm diameter to something else, like 3mm)
Now, you just have to pick the appropriate Row of values in the design table. (by calling up the design table in the relations)
You can go through each Row of values, select them, and update the assembly. (or it will do it automatically if you have auto updates selected)
Again, if you want to see a "locked" configuration, select the Row of values that you want, and pull a dumb solid, or save a neutral format.
You don't get all of those fancy BOM options like this, though. That's advanced stuff. It's easier, in that case, to do it with multiple parts. (or so I think - mabye someone else has a better way)
Check out
CATBlog!
