how to create flexible tubing in SW premium
emc007
Our company just upgraded our software suite, and the software tutorials are useless to create tubing...., anybody have any experience in building tubing and/or flexible tubes in SolidWorks
any help will be appreciated
thanks
OK, let me re-phrase my question, we have the routing package, but I need some help (from someone who has the routing package) to give some advice on how to begin the "flexible" cable routing. as far as how to make a cable "on the fly". I would really appreciate some help on this. Thanks.
This is a complex question and it should be sent to your VAR, because they can help you with this, because there are a lot of variables in that question.
Basically with Piping you start with a flange and build form tehre... Electrical is the same way, except you start with a plug, etc... The help does give you the info you need. Its just you have to decifer the help better. That's Why you need to cotnact your VAR.
Scott Baugh, CSWP [pc2]
faq731-376
