How to Create and Use a Cloning Log File
EngProgrammer
Aerospace
Jan 14, 2015
150
Dear Forum,
In the past, I've used a cloning log file to clone an assembly. It's been awhile so I've completely forget what the format of the cloning log file looks like and how to execute it. Does anyone know how to create this cloning log file and how to execute it?
Thanks.
On the log file tab, there is an option to specify an output log file. When you use the dry run option and execute the clone, the log file will be created. You can then edit the log file as desired and use it to perform the final clone operation (load and apply existing log file in the log files options).
www.nxjournaling.com
