Apr 26, 2016 Thread starter #2 T tesak Guest For all CATIA users Suhel Shaikh said: Click to expand... Hi all, everybody who works with text in CATIA V5 Part Design should try this application: Txt2Sketch - Create 3D text in Catia V5 | Scripts4All
Apr 27, 2016 Thread starter #3 T tesak Guest And for those who needs to draw text along curve, please try this: TxtOnCurve - Draw 3D text along curve in CATIA V5 | Scripts4All Hi guys, if you need to create curved text in CATIA V5 sketch (feature which is not supported by default), you can use our small utility. It is called TxtOnCurve, it is free to use and you can download it here: Applications - Some (CATIA V5) tools for everybody | Scripts4All If you want to see it in action, check this link: https://www.youtube.com/watch?v=oZUDAfPJeE4 Main features: All basic 2D curves like line, circle, arc, ellipse, parabola, hyperbola and spline are supported Unlike .dxf export where only lines are used, the resulting text is smoother and consists of lines and splines Works with TrueType fonts installed on your system Works with Unicode characters like: ! @ # $ % ^ & * © ® Ř § You can check result (and find possible interferences) in application window before you export it to CATIA You can refine resulting shape by using smoothing algorithm Thanks for your attention, Last edited: Jun 20, 2016
