zoo123
- Aug 29, 2004
- 22
Greetings to all.
I see
k your inputs for correcting a Civil error pl.
in our site for Constructing A 500SQFT NEW sTEEL SHED By mistake the anchor bolts have taken up an orientation, that will convert the structural rigidity to the Pivoted type that was planned initially for a fixed type.
Now, upon scrutiny and review , I understand that the anchor bolts orientation be changed that is difficult. Alternatively, is it worth grouting the bolts on the other sides and move on so the structure could behave as a fixed type and take moments and vertical load. The height of the shed planned is 20ft and it is a mono slope type from left to right.
The pedestal is 1ft x1ft is size ( it is 11inches in real with mason error).
The bolts are 20mm dia spread on 120mm gap and 50mm pitch . We have an extra space of 50mm on the sides to add 20mm holes to make it a fixed connection.
I added the pictures and seek your view , since the project is at a road block despite a small MSME Shed. can you advice.
I see
