Hi guys, Im new to the forum. The lay out of this board is new to me so I apologize in advance for not performing a search and introducing myself in the proper forum. I'm a Journeyman Electrician of 5 years and a sophomore in college majoring in Electrical Engineering. That about sums up me. On to my question.
I am currently working with local race shop to develop an independent oiling system, with a broad application, that is capable of maintaining a static 35-45 psi. This is the pump they have selected: it is located at the bottom of the page, the "standard" size. It is a 12v dc brush motor driving a gear pump. We did a test today and the pressure was way too high. With a 10w-30 oil at 75 degrees F, the pressure was roughly 95 psi. At 220 degrees, the pressure dropped to around 50 psi. We want to hold around 35-45 psi and planned on doing so using a user controlled pulse width modulator. Could we use some type of pressure to voltage transducer to control the pulse width modulator? Or is there a controller that could do all of this for us? Preferably this would all be analog and of course, the cheaper the better. Reliability is the important part though.
Thanks in advance for all of the help.
