how to constrain pipes to elbow
andradesilva
Materials
PT
I am doing an assembly, in which I have to join a 90º elbow to a pipe of the same section. With the "mates" command, using both "concentric", "coincident" and "tangent", I can align my two components, but not establish contact between the cross section of both components. How can I do that?
Thanks in advance,
Andrade Silva
Something I do is model the pipe route as a multibody part with configurations. Then in your assembly mate the first pipe section then the subsequent pipe sections mate the origins coincident. As a multibody part, you have one file to reference and it is easier to make changes to routing.
"establish contact between the cross section of both components"
That is the purpose of the coincident mate. You should select the two surfaces that contact each other and set a coincident mate.
I don't understand how you can have a coincident mate and a concentric mate, and the two surfaces not touch each other.
