How to connect the lead screw and nut
  • Thread starter Thread starter sendhil_84
  • Start date Start date
S
sendhil_84
Guest
Hi friends
I am having a doubt in connections. In mechanism, How to make connection between Lead screw and nut?
Sendhil kumar
We don't model the lead on the leadscrew.
As connection we use cylinder, and ad a servomotor to the linear axis of this connection. By doing this, the leadscrew and the motor are not rotating.
If you need to show the rotation of the leadscrew, you have to model the lead on the screw and in the nut and ad a cam.
sendhil_84,
you need cylindrical connection followed by joint axis setting (using two end planar surfaces of lead screw). I think this is much help for you to do it yourself.
Israr
