thien2002
- Aug 13, 2002
- 110
What do we use to connect PVC & Steel pipes? Pipe expansion required? Would that effect the insulation? Can the transition be within the concrete (thrust block) from outside to inside the building? This application is for Chilled Water Supply and Return.
Thank you
Thank you
