How to connect new DIP to existing RCP? 2
pipe78
Connect new 36" Ductile Iron Pipe to existing 36" Reinforce Concrete Pipe. How can I do? Can I use Steel Couplings Reducing? Thanks.
Why not use a concrete junction box.
I doubt they make a Fernco Coupling that big, but they might be able to help. Cheap, reliable, easy to install. That is a specific brand, I*'m sure there are other similar products. Check here:
But semo's idea is way better, if you have budget (and inlet would be less than $1000 if it is less than 8 feet deep). A junction will give you access. A junction might be required by local ordinance, so check before you spec a Fernco coupling.
Remember: The Chinese ideogram for “crisis” is comprised of the characters for “danger” and “opportunity.”
-Steve
If the junction box is unnecessary, the typical way is to use a reinforced concrete collar.
semo: Thank you. I can't use concrete junction box, because budget.
lha(Steve): You are right. That's why I am thinking about Steel Coupling Reducing: By the way, why do you give a "Remember"? You know Chinese?
cvg: Thanks a lot. I don't know if the reinforced concrete collar can be used for DIP?
I don't know Chinese. The quote is from a thesis I've recently read:
"The Death of Environmentalism, Global Warming Politics in a
Post-Environmental World" By Michael Shellenberger and Ted Nordhaus. Very good reading.
-Steve
CVG: Thank you very much about the technical resource. I'll use this in other projects, because it is combined sewer pipe this time.
lha(Steve): Thanks for your response. I am insteresting this word because I know Chinese.
