How to calculate total quantity of steel plate 1
syeedsoul
1
Hello everyone,
I am trying to calculate the total quantity of steel plate as i have to fabricate one hinge which has a 20mm thick steel plate.
The size of one sheet is 150mm* 150mm and i need to make 12 pieces , can anyone tell me what will be the total required quantity of steel plate?
Thanks in advance.
why not upload a sketch showing your finished item and the semifinish / sheet size you intend to use?
Then it will come down to geometrics & manufacturing considerations (cutting machine, cut width)
R.
Buy the 12 hinges. They are very difficult to make one at a time on a first timie basis by people with no experience from a design made by one with no experience.
How big is the hinge, width by length? How is the hinge axis where the two halves meet formed, rolled, machined...?
Bare AutoCAD can't unroll a hinge knuckle to show you the blank.
Bare Solidworks can.
Mike Halloran
Pembroke Pines, FL, USA
You can figure out the unrolled dimension with a calculator. A piece of paper. A pencil and a ruler.
You can't make a hinge that way.
